Ignition sense wire for Geek . IMAGE HEAVY!!! Non broadband need not apply
fuzzer
Glasgow
Volvo S90
Hi dude , here are the pickies for the ignition sense wire . Its the black on with the yellow stripe up it. I just scotch blocked onto it and it works like a dream. I just took mine from the glovebox light as it was closest , but , this one is good too.
if you Get stuck , get back to me.
Here is the original car
Open the glovebox and grab the trim at the top with your fingers anf give it a tug as the clips are tight.
The Pannel just lifts up and you don't need to disconnect the Gearbox connection.
This will reveal the foam padding , pull it back.
Under the padding on the left hand side you will see the loom for the 12v socket.
This is the wire , the black and yellow stripe one.
Loop it up ans scotch block onto it.
