iPod issue + Command update (2010 E250)
Discussion in 'Electronics' started by Johnerz, Jul 7, 2017.
  1. Johnerz
    Johnerz New Member
    23
    Apr 5, 2017
    Car:
    E250 CDI Sport Coupe
    Hi
    I have a 2010 E250 CDI coupe, for music I have a new iPod connected by the cable in the glove compartment. This was working fine until yesterday when the iPod decided to stop work and show the message incompatible when I connected it.
    I brought the car in March and once I got the correct cables and lightning adapter to connect the iPod to the car, the only issue I had was that sometimes the Command system froze for up to 5 mins.
    I connected my iPhone 6 via the same cable, it worked no problem, then there was a connection issue then it worked.
    The iPod is still a mystery. Has anyone else had this problem?
    I need to update the Command system, the navigation maps are out of date and I do wonder if an update would get rid of the issue with the freezing and now with the iPod thinking the system is incompatible.
    What is the best way to get the Command system updated? Is it through the dealer?
  2. st13phil
    st13phil MB Club Veteran
    7,917
    Nov 6, 2007
    North Oxfordshire
    Car:
    His - Denim Blue A220 AMG Line Premium / Hers - Obsidian Black R172 SLK55
    My wife's SLK had a similar problem, telling me that a connected iPhone was incompatible. I cured it by doing a system Reset on COMAND, but be aware that doing so will erase the contents of the Music Register, plus all navigation history and any voice associations with your phone contacts.
  3. Alfie
    Alfie Authorised Forum Sponsor Authorised Forum Sponsor
    7,751
    May 5, 2004
    Surrey/Cotswolds
    Car:
    W169 A, W205 C, W451 smart
    From the symptoms you describe you do need a firmware update applied to the comand. Your local dealer can do this or a good independent with factory Xentry (such as us at Mercedes Retrofit Specialist - Comand.co.uk) ;)
  4. OP
    OP
    Johnerz
    Johnerz New Member
    23
    Apr 5, 2017
    Car:
    Nice one thanks guys. Quick trip to the garage in the morn :(
    How do I do a Command reset myself? Might as well try that before visiting the dealership.
  5. st13phil
    7,917
    Nov 6, 2007
    North Oxfordshire
    Car:
    It's an option on the System menu.
    1 person likes this.
  6. richard
    richard Authorised Forum Sponsor Authorised Forum Sponsor
    6,143
    Jun 10, 2002
    Berkshire, UK
    Car:
    MY04 SL55, MY18 GLC63s
    Do also turn the iPod fully off and then on again. But the freezing etc needs a firmware update.
Share This Page
