Killed my PC!
If I hold the key down, it beeps beeps beeps etc.
Post #73 was written on the very PC so the keyboard is deffo working - I will have a go tonight at removing the BIOS battery and let you know.
Thanks,
Its deffo F2 - its always been from when I built it, until when I set the boot mode to CD last week.
I will let you know how I get on?
Whos taking tosh!?!
If you built it yourself surely you must have a manual for the motherboard you bought and it tells you how to reset the BIOS.:cool:
are you using a USB keyboard?
if so switch to a PS/2 one it should work then
my guess is that when you reset stuff in the BIOS you've disabled Legacy USB support
or
Does your keyboard have an "F lock" key? if so press that before you press the F2 key
beeping suggests that you are pressing a key it doesn't understand
Andy
No, a standard keyboard connect which works, but not to access the BIOS.
The PC is like 4 years old, no idea where the manual is. I will reset it tonight and see how I get on :)
Open up the panel and use a torch to look at the make of the motherboard then get into their website and download the manuals or there are info on the website read whatever they said.:rolleyes:
