bored_welsh_lad
- Mar 7, 2009
Look at all this advice.. its quality.. cheers guys and girls.. just need to keep an eye out now
Firstly, i have to confess I'm not an expert. Secondly, the experts to whom i have shown the car haven't solved my problems. The problems were that my fuel consumption seemed to be increasing over time (albeit at a very low rate). Secondly, the car used to idle at 700rpm on start from cold unless the outside temperature was very low - ie <5 degrees celsuis (say). Now it starts at 1,200rpm regardless of the outside temperature. Since cars use alot of fuel at startup to heat up the exhaust and catalytic converter in a mile or two, this 1,200rpm business started to bug me. Note that after the engine warms up the car would start at 750rpm straight off. Also, the engine temperature gauge seemed to climb to 85 slower than before. The car has been plugged onto the computer and symptoms observed but no-one could say what was going on as nothing had "failed" yet something had "changed". A new throttle actuator was fitted but at 24.5 degrees celsius ambient temperature, the car still started at 1,200rpm. I told them to take it off. I also saw some remarks from black c55 about o2 sensors and there are many comments about MAFs on the forum. So after 118,000 miles on the original MAF and original o2 sensor, I had them replaced yesterday. The MAF (if my understanding is correct) helps the ECU to decide how much air is getting into the engine. The o2 sensor helps the ECU to decide how much oxygen is left in the exhaust. Since the ECU is deciding the car needs to start at 1,200rpm, here are a number of possibilities...
1 Duff sensor data getting to the ECU (inputs)
2 Duff ECU (processing)
3 Duff equipment not properly carrying out the ECU instructions (outputs)
Well this is my view of the situation anyway.
So after the dealership I consulted failed to cure the problem I decided to embark on a little programme of staged replacement of parts, firstly those parts sending data to the ECU. So now I let things settle down for 2 weeks and see if I notice any differences. If the temperature still climbs lowly, I will have the radiator thermostat gubbins checked - it is supposed to allow circulation through the radiator only after the engine warms up - supposed to get the engine up to operating temperature quicker if it is not being cooled.
But it really is frustrating and I feel a bit like a blind man fumbling around.
So what I am trying to say - not very well - is that it is very difficult for even supposedly experienced people to understand what is going on. There are just too many bits involved to make identifying the duff bit easy.
If this doesn't cure the problem then the next candidate will be the coolant sensor/radiator thermostat. I will check the invoice and report back tomorrow.
Les
Im slightly worried about the mpg figures being quoted here! Ive never got 400 miles out of a tank ever in my c230K. Even when i drove to scotland, in 'W' mode, and did about 65 - 70 all the way there on the inside lane, only managed about 330 miles to a tank. Normally average about 290 - 300 (at a push) with a mix of town driving and short runs i.e. Liverpool/Manchester etc. When caning it in 'S' mode i can barely get 240 out of it? (btw its got a new MAF and new Cat and new throttle actuator so it cant be any of those affecting it?!)
Rob.
How much was your o2 sensor to replace Dittrich??
