>>Did you read it?
Yes, but I don't buy into the information on the page in its totality.
The thing that is fundamental is that the same extra mass that provides the extra kinetic energy, or requires the extra brake force to stop also provides extra vertical load on the tyres, and this extra vertical load allows larger tyre forces to be generated.
Here's a basic treatment of the maths of the situation - the vital point being that rates of braking are limited by tyre/road friction, the truck's braking system is more than capable of producing enough force to lock the wheels;
The work done by braking is equal to the kinetic energy lost.
Assuming constant braking force during the braking.
Brake Force * stopping distance = 0.5 * mass * velocity ^2
or, in letters,
F*D=0.5*M*V^2
The limiting brake force is given by the vertical load multiplied by the coefficient of friction
F=M*g*mu
gives;
M*g*mu*D=0.5*M*V^2
Now, here's the vital point, M is on both sides of the equation, and so, it cancels out
g*mu*D=0.5*V^2
with a little manipulation;
D=(V^2)/(2*mu*g)
Note, that having cancelled out, there's no mass term in the equation for stopping distance - heavy vehicles stop just as quickly as light ones. Also, notice the V^2 - double the speed, and the stopping distance goes up by a factor of four.
There are a few factors which do slightly modify this simplified presentation;
1) If the braking force isn't constant, you need to integrate the force with respect to distance rather than the simple multiplication
2) In reality, all the wheels will not be on the point of locking at the same time - this largely depends upon how well the trucks load sensing on its rear axles is engineered. In modern trucks, this optimisation is much better, as the presence of ABS allows rear locking margins to be reduced.
3) Heavily loaded tyres are a bit less efficient than tyres running at light load
4) There is a small lag due to the air brakes, but, relay valves reduce this effect significantly.
I don't see anything that gives a factor of 2, and I would expect most trucks to stop in distances that aren't very far outside those quoted for cars in the highway code. Of course, long, low sports cars with very grippy tyres on dry well surfaced roads can beat the figures given in the highway code by a significant margin, and there's no way a truck can compete with these vehicles!
