hismajestics
Thanks carat.Using a flywheel and crank sensor from the late m111 engines gives you a 60-2 trigger wheel, then it's just the throttle body to sort out. I paid just over 700 for an emerald ecu to run mine, not that expensive when you consider the cost of an m104 loom from the dealer....
I talked to a shop here and they recommended an Ecumaster EMU standalone (I was interested in Autronic SM3 which they also sell) for 800€ + installation for some 700€. So 1500€ up-n-running. They would use M104 existing wiring harness.
What do you think can be expected from such an investment? Gains in hp, torque...?
