OK, Mercedes have never pushed the envelope when it comes to specific power output, so to claim a doubling of power when installing a turbo system is no great claim in MB world. In the 80's MB were making 5.6 liter V8's producing less power than BMW would squeeze out of a 3.5 straight six.
Doubling of power on a M103-12V is no great claim ???
Doubling power on any engine is a great accomplishment...
The conversion you talk about would have been considered 'fine' in it's day. Time has moved on, expectations are higher.....admittedly I talk for myself, but can't see why anyone would spend a significant amount of money for an antiquated way of doing something, when it is not that more complicated to do it properly.
My guess is that you are a young man who hasn't the full understaning of many things..not a problem as hopefully as you mature you'll get the point of "value"
Let's look at the money you pour into a Nissan or the below mentioned VAG...
At the end of the day you may be very fast with megasquirt and air bag suspension..
But all the money invested is lost as the car only has value to young men who can't afford to purchase it at anywhere near your investment cost.
You have returned less then zero on your investment...
Consider period Mercs or BMW's especially those done by certain aftermarket tuners...
Build them to period accuracy and you have a fast vehicle that has value...
Two antiquated ( in your mind ) 80's AMG Hammers went under the Hammer at B-J in Scottsdale in a bad early 2011 economy at $45K +..
How many VAG's or especially Nissan's ever are even sold at an collector's auction where the buyer's have real money to spend ?
Do it less complicated your way on a platform that was inexpensive when new and you end up by going fast and ultimately having nothing to show for it...
With period performance Mercedes you have a different class of buyer who will pay for the right car and at the right money.
Difference between a marque enthusiast/collector and a young man who doesn't understand money...
I haven't got M103 /M104 experience, but have with 80's VAG engines, where piggy back injectors were used, or cold start enrichment programs fooled to add the extra fuel. Ignition advance was crudely adjusted to suit. Result? Poor lag which was often blamed as 'Turbo lag', and general non optimised performance.
Cold start enrichment has nothing to do with a turbo install...it's no more then a psuedo "choke".
Can't adjust ignition other then by the R16 resistor on USA spec cars and the setting plug on Global builds..remember the M103 used an EZL which had fixed values built in..
Turbo lag...none at all..incredible design with TurboTechnics using Garrett T2's and Mosselamn with KKK's..
Small twin turbos = no lag, spool begins a bit below 2000RPM...
Does the conversion have complex water temp/air temp/knock sensor/boost pressure/TPS,etc, etc Fuel and ignition map compensation that a reliable turbo system requires? I am thinking that is a No answer.
Why must you make an install so complicated when proper engineers in the eighties did it so relatively simple and succeeded with performance and reliability ?????
No it is much more simplistic, not needing all the items you describe required by young men who build high boost hand grenades...
If you don't need it then why have it...and as Jay pointed out does 150K +++ miles establish reliability ????
You're much too much myopic in your willingness to understand that things can be done more then one way with equal success !!!
If the OP wants a TT just to say I have a TT M103, then fine, but if he wants extra useable reliable power that TT gives, then the 'old' method just won't cut it.
You are wrong again, a pattern with you..
You admit you don't have knowledge of the cars but you act as an expert..
This is not a Jap car or a VW that you seem to be conversant about...
0-60 in 5 seconds or under and low 13/108+ rpm trap speed is not slow for a very reliable, docile street car with 80's technology...
Let's agree to disagree..I'll stand by my antiquated Mercs and when I sell them I will return my value, you continue to impress young boys with your high tech builds that come apart under pressure in spite of the high tech sensors and engine management and ride scraping the ground with stretched tires....
Keep it simple....and follow the success of those engineers who knew what they were doing many years ago...
