MAF sensor unit for W208 clk kompressor 2002 230
alano
Fife Scotland
2002 clk 230 soft top
I am looking for a maf sensor for my car.
What's the most reasonable price mb is out of the box. Every where else is from £20 up to 200 what does the forum advise ?.
I have codes for coil pack 3 which I have changed and for the maf sensor. Can you advise ?
Regards
Alan
Only one route to take just fit a bosch one, all the cheaper ones will fail within a short period of time or make your car run like a dog. If you go on Euro Car Parts you should be able to get one with 25% off using the MB Club code
Thanks for the quick reply,
I will check it out right now. Where do I get the euro parts code from ?.
I think the one in Edinburgh will not deliver so I will need to pick it up.
Thank you again,
Alan.
I think it is MBCLUB25 unless Euro Car parts are having a sale then the discount doesn't apply. You can use the code to reserve the item at a branch and then collect.
Have you tried cleaning the MAF with electrical cleaner? sometimes this works and extends the life. Also make sure it is definitely the MAF as it can throw the fault code for the MAF when it is not actually at fault. Try running with the MAF disconnected see what that does I'd just make sure it is 100% the MAF before buying another
Found a VDO maf sensor at £170 and another make for £95 at euro car parts there was no bosh.
I would prefer bosh as you advised .....
Is this not the one you are looking for?
