Mercedes W114 250 Coupe - help!
Huge progress in the last two days, shame no ability to show it!
If it's the same as the 107 the axle shafts won't go back in with the brake calipers mounted. Although the diff mount is different to mine everything else looks the same. The back cover had to come off anyhow to get the circlips on. Good time to check axleshaft end float.
The axle shafts went on with the calipers still in place, tight I was told today when I asked (I do listen) but in with no issue. Shame I have no ability to upload the photos.
The central locking- in addition to the doors will lock the boot and petrol filler flap. :dk:
I learned from a similar discussion on the W114 Facebook site that only Uk cars came without a petrol cap lock. Later cars all had centrally locked filler cap.
Computer back with another new logic board (this has cost Apple an arm and a leg - I can fault the kit but I can't fault the service). The last of the old batch of photos before I upload the new lot. (The repaired MacBook can't get Photobucket to work any better.)
Bootlid on.
I'm really pleased with it all underneath (as well as on top). I have some more photos but I was using the wrong focussing mode for low light (black cat at night in coal hole mode not switched on), so I'll re-shoot them on Monday, when we start work on fitting the loom
The contrast with how it used to be is immense.
Not even half way through the year and we can confidently announce the winner of the Understatement of 2016 Award is Charles Morgan!
A very nice sentiment vijilants, thank you. It would need me to enter it though into such event, which really isn't my thing, and given the Megasquirt conversion I doubt the fine, be-logoed short shirted judges of the MB Club would give it house room.
Mind you, if they see the OM606 conversion of one currently being done (elsewhere) they really would have a fit. As would the enforcers of construction and use regulations.
New doughnuts front and rear
New propshaft centre bearing and new bearing housing (plus protective cap)
Exhaust bracket - John fabricated one as there was no sign of one in the parts collection.
Charles
You may have to buy a house with a glass floor and a cellar.
It just looks fabulous.
Been a busy few weeks for Simeon with a tech down and numerous small jobs turning into big ones. An example - they had a
Jaguar E type series 3 that came in from America and had been restored elsewhere. The car ran poorly so it came in for tuning. It turns out that the two rear Strombergs have had their internal gubbins changed over to a type that is not adjustable from above and needs the adjusters below, which don't exist on the old plates. So a lot of investigation to establish what's wrong, tracking down the correct part, when tuning doesn't seem to work and a small job turns into 4 days with other work being necessary.
Another, a lovely restored Bentley Mark VI Park Ward drophead was in having broken down - the dusty rear was covered in handprints showing clearly the reason it was there before I had to ask. Having got it running, the front brakes were found not to be working at all, and are immensely complex to adjust and bleed. So as the owner was hoping to pick it up and Simeon had to deal with something else, I was asked to test drive it, having experience of driving 40s cars (my Allard is from 1948). On crossplies, so the car wandered, it had its gearchange on the right side of the drivers seat (I'm used to a manual on a lhd car too), which was very precise, but no (or damaged) synchromesh on the lower gears so a lot of crunching as I'm really no good on double de-clutching. With Billy operating the indicators we got it started, changed the running speed and all other things doable from the steering wheel. Progress was stately as it wasn't my car, and having tried low speed braking, it pulled hard to the right. So back to base after a 10 mile run to find the left brake cylinder leaking fluid. So more work and no car for owner.
All this to show that my car is not an orphan but is temporarily having a rest and will be back on the ramp next week to get it finished off, then off to the trimmers in early July.
A trip to see what's been going on over the last couple of days. A lot of detail work plumbing in the steering box etc, so another photo from underneath. As I was taking it, lying flat on the workshop floor, John thought it would be funny to see what would happen if Bramble, the workshop spaniel, turned up. As if on cue...
I tried to get closer to the centre of the car but some newly arrived clutch fluid had pooled in the middle under the lift. Clutch is now fitted and reservoir connected, so all three pedals work, although the throttle does need an onward connection to the engine.
