brucemillar
- Nov 18, 2010
- C55 AMG Wagon - W124 300te 4matic Wagon - BMW 4.8is X5 E53 - SWB Pajero 3.5 V6 24v
I suspect that DRUK will not be offered any TATTOO work in the near future ;ˆ)
picture of the fuel rail attachment from the old 280 thread.
the new
the old
you can actually see the 3 black U shaped brakets that attach the fuel rail top and bottom better here .
THE THOUGHT NOW OCCURS- If the injectors are now retained firmly both in the cylinder head/manifold [ front end] and effectively sealed into the fuel rail [ rear end] by the new rigid fuel rail is there any need for the old injector retaining plates ? - could the mounting bolt holes for said retaining plates not be used as mounting points for 3 fuel rail retaining brackets? these would then have dual function- keeping the injectors in place and sealing on the fuel rail? Or is that too easy?
Space is very tight - we are going to have to move the throttle bar linkage visible in the photo below about 1cm to create space for the return pipe.
