Cleaned the beast this morning. As you may know, I reckon my aerial connection has gone a bit iffy. If I detach the boot door card...will I find it there? Don't want to open it up in vain!
Thanks, you were good enough to send this link to me before. However, I can't make out any real detail of where aerial connections are between the head unit socket and the rear? I need to trail it from the head unit and check the connections?
Sorry about that, I would start at the rear where the cable plugs into the amp, join a piece of cable or wire to the center connection and see if the radio improves, if it does you know then that the fault is either in the aerial its self or the amp
