ml xmas tree lights
golferson
ml 270
last week or so bas/esp/ets/abs and brake wear light come on when braking but only when nearly stopped! if i touch the brake pedal again it goes out, the pads are very worn and due to replace them this weekend. only replaced the brake switch two weeks ago (from mb) because of brake light stuck on. any clues anyone?
I have read there are a couple of part numbers for the ML brake lamp switch, the most common cause of fairy lights as you describe is the brake switch you have already replaced. Did the numbers check out to the original?
All the best Steve
thanks just read it! brake switch from mb as per vin .suspect steering angle senser, might go back to mb and suggest faulty brake switch and ask for reduced star diagnostic,bit cheeky but you never know, ps car still runs fine but never go above 3000rpm anyway.
