I am faced with yet more frustration with the car while striving to get the front end including the steering as close to perfect as I can on a now 20 year old car!
Today we replaced the left hand side lower ball joint as this didn't get done with the other side earlier this year.
Now I hoped that this would fix the steering groan completely...... it hasn't! Has not even made a blind bit of difference to it.
To sum up this car has now had the following items replaced over the last few weeks...
> steering damper
> complete centre drag link
> both track rod ends
> both lower ball joints
> idler arm bush
What's frustrating is that the steering groan is there still. This still remains to be an issue 'only' when turning right (like a small roundabout) or when going from full left lock to full right lock.
I'm not sure if there is much more that is able to be replaced relating to the steering system if I'm honest!
The next biggest bug bear that I have is the massive inability by now 2 garages to get the tracking spot on! It has now been in 3 times and has been altered every single damn time! First time was at Hawleys tyres when it drifted off and started pulling left after I brushed the curb... second time was again at Hawleys but it very quickly became obvious that the wheel was too far to the right and the car was pulling left still
Third time was at Dexel tyres after all of the new parts were fitted and Hawleys had supposedly tracked it spot on.... now the wheel is slightly too far to the left, the car is pulling left slightly and the outer edge of the left tyre is feathering
How hard is it to track these cars and sort out the steering angle? Needless to say my pockets are feeling the burn at the moment.
Anyway this is how the underside up front is starting to shape up...
The damp on the sump is from the cap failing a while ago, its not actually leaking.
And back to this groaning steering issue.... as seen above I have ruled most of the common faults out. So naturally I am starting to look in the less obvious places!
First up, the power steering pump/fluid. I'm told that this fluid should be green and not atf. The system was around 90ml too full so I got the level down by using a 10ml medicine syringe (the handy thing about having children).
This is what came out off the reservoir....
Certainly not at all green!
And held up to the light....
Certainly a very red tinge to it and it smells just like used atf (the dexron III kind at that too).
Could this be something to do with the groan I wonder? The wrong grade of oil and in need of a change?
The other thought in mind is certainly the upper arms at the front. This is the only other point that I can think of that is under load while turning, particularly that handy ball joint that can't simply be swapped out!
Any further ideas welcomed at this stage on all of the above issues. I have already tried the typical bloke things of ... swearing at it allot, threatening it with all manor of scary recycling options, throwing money at it and sending it to garages where apparently 'competent' people are supposed to fix things. Nothing so far has resolved the issues and my funds are a little low until the beginning of next month
