Wigglesworth
Indeed it is....
I have taken some pics to outline what I have.
These are the fan wires coming in from under the headlamp, the green one is from the ac pressure? Switch, the 2x black ones are from the fans!
These are the 2x connections for the ac switch thing!
These are the relays that live under the washer bottle! The forward most black one switches the fans on when contact is made (and my fans indeed are spinning up when you do so). I have fitted the central relay as it was all taped up... not made a difference to anything so I will likely remove.
And this is my fuse box!
I can tell you that the rest pressure on the ac (engine off and pump not running) is around 55psi!
I am not going to try adding more gas as that is a big No No without all of the weights and being able to evacuate the old gas and oil.
I have pondered if the gas pressure is just too low in the ac, it blows cold but that's no set guarantee that it is all as it should be.
Oh and before I forget entirely....
Proof that there is no fan control module
Even the Haynes book of lies outlines it's existence.
Interesting that the previous owner had folded over that particular page! Me thinks this has been a gripe for a long time.
Thanks for all of the help guys by the way it is greatly appreciated, I would be stuck without it in all honesty
