Thanks. Tried it and nothing appears to happen. There's no option on the cluster to turn the function on/off as far as I an see either
Looking at your pictures... You do have the active cornering headlights.
It needs to be switched on via star.
Olly turned on the option in star after replacing my BCM.
If there is a fault message in the cluster after turning the option on then the previous owner was hiding the fact that either one or both headlights are faulty.
About £600-£650 per headlight from the dealers.
Or if you know how to spot them on eBay £40-£140... Doubt you will find any, I keep buying them for spares
