benjaminD
No. It is the number you can see looking at the bottom of the windscreen from outside - passenger side. Probably starts WDBxxxxxxxxx
Should also be in the service book
Ok will do
Here is your datacard. I can't tell if you have 7g or 7g+. It is Option 427 and noted as 7 speed automatic transmission. Also says its a 722.908 transmission.
I think the 7g+ gb is a 724.2
Active park assist the car will park itself either parallel or will reverse into a parking space in supermarket car park.
When your driving slow do you see a blue P sign in the speedometer? It will then point an arrow as you drive past a space if you stop and engage reverse it will say activate park assist you press ok and then follow the instructions basically you just select the gears and press the accelerator the car does the rest but you have to have faith lol. Parallel park works best the supermarket type bays are quite scary also if your trying to park on the right hand side you need to use the indicator otherwise it won’t prompt you when it sees a space.
Collision warning red triangle when your too close to a car also it knows how hard the brakes need to be applied if your going to hit something so as soon as you touch the brake peddle the car knows how hard to brake and does it.
Wow thanks for this. Pretty smart features. The dealer didn’t even tell me!!!
Probably didn’t know it did it to be honest!
No problem now you just need to go find some parking spaces to practice in lol oh and it will drive out of spaces too if you’ve let it park itself when you start up and indicate to pull out it will ask if you want it to drive out.
Thanks mateNice car
Sent from my SM-T280 using Tapatalk
