No more scraping of windscreens?
hot ketlle too much dangerous for screen, I guess
Nah, absolute ****** and an Old Wives tale that 'Cracking Screen' lark! :rolleyes:
I've been using Hot water on heavily Iced screens for 25 years on 10+ vehicles without any problem what-so-ever!
Yes, I use a Kettle but only for convenience in pouring, I actually fill it with Hot water out of the Tap and not BOILING WATER!
One full Kettle does the whole car and ya good to go in 2 mins flat.
Modern screens are very robust and I've seen a local DNO Electrician employee throw a boiling hot kettle at a Transit windscreen and let go of the Kettle which promptly hit the windscreen full chat along with the boiling water and it still didn't break. :eek:
As Arthur Daley say's...."Stand on me my Son, it'll be fine!" :D
+1 for warm water whilst others are busy scraping ice from their cars.
Sent from my iPad using MBClub UK
Get a Ford with heated front screen - fantastic!
I used to work for Triplex back in the '70s when they first perfected a wired windscreen like in the Fords - and I believe held a patent.
It was an extension from aircraft windscreens with wired heating.
The Directors all had a wired screen in their 3500 P6 Rovers.
No-one was interested as it cost too much - at the time basically a few quid per unit if enough could be made.
Now folk will pay £90 for a hokey coating?
I also use tepid water, not hot, to melt the water, and then a good squirt of screen wash to clear away the water and prevent refreezing, currently at a ratio of 3:2.
MB screen wash at that concentration doesn't come cheap though!!
The BMW stuff does though. Currently running at a concentration that will go down to minus 22 but their stuff will go down to minus 63 neat and its still cheaper than Halfords.
I'm pretty sure patents only have a 20 year life from when they are granted, so Ford won't have an exclusive on this anymore.
A lot of the early 911 boys buy front screens with heated elements in them just to stop the screen misting up as the air cooled cars didn't do a great job of keeping them clear (but nowhere near as bad an air cooled VW Beetle).
I'm with the kettle full of hot water brigade - not cracked a screen in 30 years.
As I watched my next door neighbour taking ten minutes and freezing his hands scraping the ice from his windscreen, I waited until he finished and then went out and poured a jug of warm water over my windscreen.
He told me that I shouldn't do that, it'll crack my windscreen...:rolleyes:
I've only used the technique for the last fifteen years without any problems, what do I know?
+1 to lukewarm water.
Even if a patent exists on a product, another manufacturer may use it "under licence" and pay a royalty, by agreement.
As I understand it, Ford want a fortune for licensing to other manufacturers. In effect making it non profitable, and therefore the manufacturers don't bother.
There are a number of ways to make a design your own for longer than 20 years - registering a design, trade marks, exclusive deals with glass manufacturers etc.
Oh, and warm water only works if you can reach the windscreen. Easy on the SL, but not so much on the S-Max!
I think you'll find that only cars produced by Ford (and any Ford owned such as Jaguar at the time) had heated screens because Ford patented the concept many years ago.
I recall an ex gf having a '93 Escort Ghia with a heated screen :D
I've had heated front screens in MINIs so I think its more of a case of other manufacturers can't be bothered or think that they would not be worth introducing.
Old 126's could be had with a primitive heated screen, not usually UK market ones though. It was just a coolant tube that was routed under the screen but also through the washer fluid tank too.
My friend recently had to have a new screen put in his W220 circa 2002 I think was the year of the car, a straight six motor- he discovered then that the screen was an electrical heated type.
On my 126 the windscreen just doesn't tend to ice up too badly, and the heated washer fluid is brilliant, I can usually get in and go with no scraping needed, or warm water.
