Does the variant setting menu still work since your slip up?
Press and hold 5 and then also 3 and then also 7 - after a few secs you should get the variant menu where you can hopefully select W219_ECE and then via the top left soft button called "keypad", also select the same model.
In theory that should take you back to ECE spec with the correct menus and soft keys.....(or possibly to the point where the correct head update will load).
Good luck!
Tried on that one but still no luck. when i press the video button its still showing satellite radio. thanks for your suggestion
