MrGreedy
On re-reading, that should have been 'nice fan jet'.
Not whatever a 'can jet' is!?
Anyone prepared to stick their neck out on the how-close-is-too-close question.....?![]()
A Karcher K2 isn’t powerful enough to cause damage IMO unless your paint is already damaged.
If you’ve got lacquer peel then it’ll blast it off - but if the paints fine then I doubt any issues will arise.
I'd probably say 5-6" is closes (my Mrs may argue I mean 3" but ignore her haha).
It sill depend on the lance you're using, I assume it's a similar lance to the one on my Karcher. I twist it round to the highest pressure position on the nozzle but don't realistically go closer than that. If there's a stubborn bit of dirt, don't be tempted to move the jet closer and closer to get rid, save that for the wash mitt.![]()
I think he does mean metres, ie would never use a jet wash on his car.I think that you mean 30 centimetres![]()
I did mean metres, because like being on a superbike, you sometimes get carried away.Oh I see... I have a nozzle that is adjustable. It's like riding a superbike, it only goes as fast as one dares open the throttle...
I was tempted and did do that, but will reconsider!
My opinion is that it would take quite a bit of experimentation to dilute it enough so that it is effective but not to clingy. It is effective from 1% dilution! A citrus pre wash is a better bet as surfex is designed for grease and oil, predominantly. If you want to decontaminate, then Korrosol is a great one to use on bodywork and as it turns purple, you can see where it works.Good idea, or bad idea?
