KLP 92
I had my wheel alignment done on my W211 E Class due to excessive wear on the inside edge of the front tyres.
I had 2 camber adjustment bolts installed and 4 wheel alignment done. After collecting the car i noticed that the steeering wheel position was off centre. if i drive on a motorway the steering is approx 1 inch to the right so not level flat when going straight.
The car has been back to them 3 times and various adjustments done but position the same. On my last visit i was told to book the car into mercedes and have the steering wheel position sensor reset as this is what was causing the problem.
After having that reset at an independent specialist it made no difference and i'm now left with a car that although may not wear the tyres excessively on the insides anymore, but the steering wheel isn't in the middle.
Any ideas on what i should do as i believe the garage isn't actually able to rectify the issue, 3 vsiits to correct the issue so far!
