- Feb 8, 2007
- Location
- Portsmouth, Hampshire.
- E55K SL500 E250X2 Smart44 Brabus Track car E450Cabriolet X350 Pick up
Me thinks it is in the tyres....
I'm would be happy to be found to be wrong, i will even hold my hand high up in public knickers down and say so but this will not solve your complaint.
I could also pants on for paragraphs quoting geometric examples but this also will not solve your problem.
I keep trying to say to you the solution is outside of the chassis, a comment regarding fuel i will pay for and inspecting the external chassis for a solution would be free..... Other than that i'm done.
Just remove the steering wheel and refit a couple of notches to the left. Problem solved !
cheers
talbir
It seems logical to me that if everything is in alignment that the ONLY thing adjusting the track control rods can do is change the position of the steering wheel. If left and right are adjusted exactly the same amount then the wheel straight ahead position will be moved (rotated) but surely absolutely nothing else will have changed on the vehicle alignment?
I really would like to understand why this is wrong?
cheers
talbir
I really do wish someone would answer this... any chance?
Not quite as simple as that
A real shame that any garage gets named here with a problem, it's simply not fair on the garage as reputations can be harmed very quickly. It would be nicer to see individuals ask for techncal advice on an issue without naming the company involved.
cheers
talbir
and Talbir you should know what i'm like.
