Dazsw
- Feb 17, 2020
- Location
- Airdrie, Scotland
- 2012 C63 AMG Coupe, 2015 VX Astra Tourer CDTi
Your bodyshop guy is correct, as long as they are using modern paints, you can apply polishes and waxes whenever you like, unless given specific instructions to the contrary.
Orange peel I would leave alone, removing heavy orange peel like in most Mercs removes a significant amount of clearcoat, which in turn means scratches in future couldn't be fixed and may need painted due to a lack of cleatcoat, cars coming back from bodyshops will most likely have some orange peel present, unless going for a proper high end show finish they won't spend the time to remove it all as on a daily drivers it's a waste.
Also, removing lots of clear leaves the base coat potentially susceptible to UV damage as this is one of the main things the clear does.
