D
Deleted member 11979
Guest
My 1991 R129 500SL has developed a clonk noise which can be felt through the steering when under certain conditions. The noise is coming from the front passenger side of the car.
When the car "twists" it happens, i.e when reveresing down our drop kerb with a bit of lock on for example. It doesn't happen at speed, or when both wheels are up and down, i.e speed tables. It doesn't appear to happen on potholes.
You can hear it happening from inside and outside the car.
I have had 2 garages look at it now, both have checked all the bushes, springs, top mounts, shocks and ball joints, all is fine.
The first one replaced the anti roll bar end bushes but this did not help. The steering damper is fine, the wheel nuts are done up etc.
Does anyone have any ideas what it could be?
Any thoughts would be greatly appreciated as it is getting annoying, thanks a lot in advance
