R171 Parrot Installation
ian black
I have a 2006 SLK R171 with Audio 20 installed, I am trying to install a Parrot CK3100 with Parrot steering wheel controller. Can someone tell me where to connect Mute connection and where do I pick up the Canbus High & Low. The Parrot manual says pin 9 & 11 are the correct pins from the back of the Audio 20 but the Parrot website says pins 1 & 2 in the Fakra connector.
Pin 5 should be mute, pin 1 CAN high, pin 2 CAN low, this is at the Audio 20 connector side of course, don't know about Parrot.
I think there was a thread on this same installation recently, could go and search to double check and perhaps for other info.
Stuart from PARROT UK has also replied & confirmed that the connections are in the FAKRA connector, he says 'On the SLK the CAN wires are located in the small white plug that is housed in the Fakra connector behind the radio' CAN HIGH is Brown/Red & CAN LOW is Brown.
