I'm not sure if this is on the right part of the forum, but here goes.
Not been my month so far, but the right rear quarter window packed in working tonight. In normal use it would retract a small amount on opening the door and return to position when the door is closed (presumably to secure the rubber seal). Now all I get is a whirring/grinding noise from behind the trim, but no up/down/forward/backward movement.
Same noise occurs when trying to lower the window with the button on the driver's door and it certainly sounds like something has come adrift. Anyone have any experience of this happening and what's likely to be cause and fix?
Any help will be greatly appreciated.
