Diesel Benz
I am now fully stuck...I pulled Radio out with the tool but it looks like....Radio has got some sort of circular clamp which has got hole in middle... when I try to pull it out with tool...Woden texture facia also try's to come out.....to pull radio out do i first need to take facia as well.. if yes how is it secured ....is it secured by bolts...Its night mare at the moment...Please direct me in right direction ...............Please help
I'm confused, how did you pull the radio out if you did not remove the centre console cover? Is the radio an MB OEM radio? If yes, you should start from removing the cover (like mentioned in the pdf that was referred earlier), and in order to to this, you would need to remove the centre air nozzles.
