I sat my driving test circa 1975 and was told the requirement for hand signals ceased about a week later .I seem to remember having to demonstrate hand signals as part of my driving test - would have been early 80's. Do I remember correctly?
Try it somewhere it won't matter if the car creeps - on all my cars where the hand/parking brake is correctly adjusted , it will hold the car in drive , even slightly downhill . If a particularly long wait , such as at some roadworks , I may pop the car into neutral or park .This makes sense; I’ve often wondered about it - and even more so with brake lights. I feel for the car behind sometimes at night when my huge full-width tailgate-top brake light is stuck on at junctions. People behind have their faces illuminated bright red in my mirror. But it’s not easy to cancel it with a column shifter and pedal-operated parking brake...
Yes , manual with a FOPB was a faff - I had that in the W124 E250D manual , but with an auto it has never been a problem , other than the 'soft shoe shuffle' to apply it - where you have to take foot off accelerator onto brake pedal , at same time foot off brake onto parking brake pedal , to apply .W201's had a conventional handbrake but there was a down side in terms of it's effectiveness. Because of the very small parking brake shoes inside the rear disc hubs it needed quite a strong pull to hold the car against the creep of an auto box. That is probably the logic behind a foot operated parking, at least where inadequately sized brake shoes have been used.
The big upside to a conventional hand brake for manual transmission cars was ease of hill starts. Until hill start assist came along the foot operated handbrake was a 3 act farce with a manual transmission at least until you acquired the skill and timing to make it work.
If you are carrying out the manoeuvre uninterrupted then yes , but if you have to stop and wait for a sequence of traffic lights to pass , then out of consideration to people behind after dark , you should cancel them , or remove your foot from the brake , until you are ready to move off again . It is not a problem in daylight , perhaps even in built up areas with bright street lighting , but it can be a very real problem in unlit places .
Remember , even in the novice driving test , it is a requirement to apply parking brake and select neutral when stopped at lights , not to do so is recorded as a fault .
Makes it tricky to put the car back into drive and release the parking brake - need 2 right arms to be able to do it in time to drive off! But I’m giving thought to using the parking brake to hold the car still whilst in Drive, which makes sense. Although... don’t modern Mercs disengage drive when the brake is held on? Releasing the brake and using the parking brake might therefore cause more wear on the ‘box?What is it with the ( presumably new type ? ) column shifter ?
If there is no one present on the approach , no need to signal at that point ; if someone appears on the scene , you signal BEFORE moving off - perfectly considerate .
All I can tell you is this is taught by IAM , RoSPA , Police , Fire , Ambulance , Army and no doubt many others .
You’re correct. My JZR doesn’t even have doors. Nor side windows. Nor roof. Nor a fourth road wheel.....Open cars don;t need windows
I don’t really see that as any different to manual column change which , LHD or RHD , is always to the centre of the car , as is the umbrella handbrake which normally accompanies it : it was always just a matter of selecting gear first , then releasing the handbrake . It mostly isn’t difficult to anticipate the changing of the lights , but even if not just takes a couple of seconds .Makes it tricky to put the car back into drive and release the parking brake - need 2 right arms to be able to do it in time to drive off! But I’m giving thought to using the parking brake to hold the car still whilst in Drive, which makes sense. Although... don’t modern Mercs disengage drive when the brake is held on? Releasing the brake and using the parking brake might therefore cause more wear on the ‘box?
The argument would not hold any credence because it is incumbent on a driver to be aware of his surroundings, and cancelling a trafficator at standstill is the correct thing to do , besides not all vehicles have mechanical or electric signals , so one cannot depend on that .I would totally agree about securing the vehicle when at a stop, I taught my daughter to drive and after 3 years it still annoys me she does not use the hand brake when stopped, nobody in the city does this. I do see the brake light dazzle issue, if you follow the code and secure the vehicle at a stop its a none issue.
I'm still not convinced about cancelling the indicator.... In the current claim culture world even if its not your fault and you were stopped in the centre of the road waiting to turn right but not signalling and someone hit you for example, then I could guarantee the insurance or claimant would use your lack of signal to even up or even remove the blame.
I would agree turning off the indicator might be the gentlemanly thing to do, however too many un-gentlemanly folk will use it against you.
I do too , in daylight .Well I admit I keep my foot on the brake while waiting at a traffic light,but if it is a road up with say a three way lights or a traffic jam thats not moving I put the car into park and put the hand brake on I never just put the prawl in the box
Much of Roadcraft is indeed written for emergency response drivers .I've always found it hard to accept all of the guidance given in Roadcraft when it tells you things such as this.
Police drivers, however much they may argue, are not perfect. They may not have seen someone on their approach, but that is not a 100% guarantee that there is no one there. Why write that it is not necessary to signal, when a signal takes so little effort and may help prevent misunderstandings?
Why do you need to manually release the parking brake ? My first column shift Merc was 2013 E coupe and had two more since then and they've all automatically released the handbrake when you press the accelerator.Makes it tricky to put the car back into drive and release the parking brake - need 2 right arms to be able to do it in time to drive off! But I’m giving thought to using the parking brake to hold the car still whilst in Drive, which makes sense. Although... don’t modern Mercs disengage drive when the brake is held on? Releasing the brake and using the parking brake might therefore cause more wear on the ‘box?
Exactly so. You need to display your body language because you can't trust anybody else who may or may not be there.Well I know driving instructors were told of the "new rules" of only indicating when somebody is there,but that is a poor rule,and as it has been in force for at leat 10 years we have loads of drivers now who hardly indicate at all,we have all seen them as you are about to overtake on the motorway you are maybe three car lengths behind them and out they come no indication,this also happens when the said driver is overtaking him/her self they do not alert the car in front who might well have decided to come out,and the thing is if there is a serious accident the police canvass witnesses who are bound to say that car did not indicate,so I know I seem to be in the minority,but at 3 am on a slip down to a deserted motorway I still indicate as I speed up to join no traffic that I can see.
I’ve had the car a while.......Cool car that. And you look very young in that photo too.![]()
OK , let's deal with this .Well I know driving instructors were told of the "new rules" of only indicating when somebody is there,but that is a poor rule,and as it has been in force for at leat 10 years we have loads of drivers now who hardly indicate at all,we have all seen them as you are about to overtake on the motorway you are maybe three car lengths behind them and out they come no indication,this also happens when the said driver is overtaking him/her self they do not alert the car in front who might well have decided to come out,and the thing is if there is a serious accident the police canvass witnesses who are bound to say that car did not indicate,so I know I seem to be in the minority,but at 3 am on a slip down to a deserted motorway I still indicate as I speed up to join no traffic that I can see.
My first column shift mere was my 1957 W105 219 - no such links . Column shift continued until at least W124 - no such interaction .Why do you need to manually release the parking brake ? My first column shift Merc was 2013 E coupe and had two more since then and they've all automatically released the handbrake when you press the accelerator.
