sunman
- Aug 15, 2004
Sunman - how does the trunk closer function ?
I'm thinking it may be a nice addition to my SL
R
Hi sunman, well done mate. Its a very neat piece of job. How did you managed to get the reverse camera fitted perfectly next to the handle. Is there a ready hole/compartment? On the other hand, where and how is the reverse camera connect to? COMAND APS? "AUX" Jack? Kindly enlighten me. Many thanks.I did not add it finally to my 203 since mechinically it was not possible without welding in brackets. The trunk closer is hydralauic and works well. The camera does automatically switch on when in reverse and also draws lines for you on the screen so you can parallel park or back into a spot with guidance. the closer on the SL is pretty expensive. Almost 5k dollars in parts alone since the vario roof pump has to be swapped for a pump that handles the trunk closer struts as well as addition of 2 control modules.
R
Hats off for the work & thinking that went into this but I have to ask, does anyone actually need a camera on the back or an automatic boot closer? IMHO even as a factory option they're silly, expensive gimmicks which in years to come will break & cost more to repair than the car is worth.
I believe this was a factory rear view camera retrofitted. Since the option is available from the factory, if you just use all the necessary parts, you will have a place ready for the camera.
Also since it is a factory option, one would not use the normal AUX jack for it. The early W221 cars use a pretty complex control box for the rear view camera, the box takes care of drawing the dynamic lines while in a later version COMAND should do that.
my w221 is sep 57
can anybody recommend a camera that they have had fitted and what company to use for fitting
and finally could if i plug any old camera in ,would it display on sat nav screen
