Ditto.... Well put... I have been thinking the exact same!
Looking forward to responses on this....
Right... I'll give it a go. It is important to note that chipping and mapping are two different things. A good map is the best because it is custom to the car, a chip... meh.
Previous motor to the MB was an 03 Subaru Impreza WRX which I had mapped to 275bhp. This involved taking the middle cat off (3 on the car originally) and changeing the back box and intercooler hoses plus a session with a real mapper, a laptop and some 'det cans' (headphones to listen to the engine in layman's terms.
275bhp is an awful lot for a 2.0 engine but the car was just rolling onto 100k and still pulled like a train.
The fuel economy was the same, if not marginally improved and despite the loss of a cat still passed the MOT and met the emissions regulations.
So how can it be done...?
Well, thank to the EU who tell manafacturers "you must have xyz catalysers on a car" and other such rules rather than letting engine experts reach targets through their own genius many engines are heavily restricted by the manufacturers.
Fuel in the system actually protects the Cat, most cars overfuel by quite a lot to make sure the Cat is protected, otherwise it crumbles into the exhaust. If you remove it (or one of three as I did) the mapper can look at the engine performance and see what the ecu is seeing and telling the car to do. While driving along they can order the ecu to lean out the fuel which makes the car go better and improves the fuel economy.
If i'd taken all 3 cats out my mapper would have been able to lean the fuel right out and take the car to 290bhp with no additional fuel use!!!!!
This is why mapping is better than chipping. Engines are built to a tolerance, the manufacturer sets the levels which will give the best trade between performance and reliability but as with any manufactured product, each one if different. A mapper looks at what your engine is doing and customises the ecu for that engine, releasing power in the process.
A chip on the otherhand or a generic map simply uploaded to the car is another 'one size fits all solution' and doesn't actually take account of how an individual vehicle is able to perform which is why they are cheaper but more dangerous.
Does all that make sense? I've just typed all that without planning it out...
m.
