Small Job That Turned Into Big.....
Why does that always happen?
Got my 3 replacement bulbs (thought: I'll get an extra bulb in case I bust one). Went to MB parts this lunchtime, none in stock so went to Hellfrauds on the way home. Saw *something* that resembled the bulbs but couldn't be sure, so I strode along to the Vauxhall (!) dealer up the road and asked them "Why, no problem at all sir. How many do you want?" the assistant trilled. I took three at a cost of just over two pounds. Thought I might have time to do it before it got dark.....
First bulb went in a treat. Wrapped bulb (..now just a "capless" bulb a la Hellfrauds BTW - could have got them there) in tissue just in case, and the first one clicked straight in. Easy I thought, thinking of that beer can with my name on it. Second one wasn't so co-operative, but I persevered. It slipped into the annals of the heater controls, leaving my with tissue and tweezer in hand. B*gger! Oh well, got one extra for this reason. Wrapped in tissue. Placed in tweezers. Aligned with holder. ZAP! Lightning struck twice.
Great. So I've got a half done job, and a heater control box that would probably remind me of my clumsiness every time I took a corner a bit keenly. With dinner almost ready (and darkness fading fast), there was only one solution: the heater control unit *HAD* to come out. Then, it had to come apart.
So, out I trudged, torch in hand. Stereo came out, bit of a job with the cage as M-B obviously didn't think some butter fingered goon of an owner would want to take it out so soon, but this was the only real challenge. This exposed the two Phillips screws that held the wood finish over the radio/heater/switch bank. Away it came, the switch cable feed concertina'd around the binnacle for the hater controls. After that, the heater control box came out by pushing two locating lugs to the left and right, out it came, freeing itself from the Universal Joints that control what vents the air comes out of (always wondered how it did that). A quick release of the quick-release cable block on the heater box, and away we were. Common sense prevailed - I wasn't going to take this baby apart in the darkness of the car interior: this baby was coming in with me!
A quick reccy of the heater control unit (I'm going to call it HCU from now, should have done earlier...) showed about 8 recessed plastic tags holding her together, 4 at the top, 4 at the bottom. My thinking was that if I could "loosen" the bottom 4, I could pull it apart enough to liberate the bulbs trapped inside. Then, I could put it back in the car and have another crack at it. SCREEECH!! Hang on, silly billy: why not put it in with the HCU OUT of the car? That way, if I sacrificed another bulb to the HCU God, I could remove it easily. Good idea, that man.
Well, 4 bottom lugs gently separated and much gentle pulling apart later, what should pop out onto my study desk but 2 capless bulbs similiar to those I'd lost earlier - hoorah! Now lets go to work: Tissue round bulb, tweezer round tissue, hold the HCU up to the light, left a bit, right a bit....FIRE! CLICK! Yes! Its there. Remove tissue and tweezers, a quick shove to make sure the bulb is home, and we're ready to go out to the car again. This should be a walk in the park. After all, its just the reverse of getting it out....right?
Well, kind of. Apart from the fact you have to reconnect the two controls for the ventilation control part of the HCU, and I can only compare it to trying to do a Rubiks Cube with your arms behind your back, i.e. not bloody easy at all. But, we'd come this far and I was determined to clear my passenger seat of clutter before dawn, so eventually I got it working. I could just about get my hand behind the HCU to locate the male and female parts of the controls. A quick fire up of the fan and a full turn of the vent knob to make sure all is hunky dory, and y'know, it seems smoother than it was before. Maybe I was destined to take this damn thing out. Maybe its a placebo effect. In truth, I'll never know.
Then came the big switch on, would my new bulbs be okay? In all honesty it was a total anti-climax what with all the other drama, sorry challenges that had been thrown at me. They worked. No white bits where one of the little covers had snapped off. Just the HCU lit in all its glory. No gentle prodding to light the bulbs, just lit straight up. Heck, I even had a spare bulb. Not that I needed it.
Top bank of switches went back in with the wooden panel, screwed back in. Wrestled the radio cage back into place, got a bit bent but placing the radio back in it soon straightened it up again. Placed all the radio wiring back in, front back on the stereo, job's a good 'un.
So, if one of your bulbs goes in your heater control unit, don't worry. Its a piece of cake.
Off for that beer now. Better late than never.
ATB,
Greg
