Rubber steering boot in engine bay
AANDYY
Blackpool
E300DT-W210-1997-Elegance-Azurite Metalic Blue. (Don't mention the rust, LOL) Running on WVO. 65k m
Not 100% sure of terminology here.
In the engine bay on my car there is a rubber steering boot on the steering shaft coming through the bulk head, mines split:crazy:
Is this a diy job, I'm fairly confident, I've done wishbones and CV boots before etc.
:D
Thanks for that, does it let alot of noise through?
I did think my car could have been quieter.
It's right next to the exhaust and if split at the bottom will be split more further up so does let a noticable amount of noise in.
How much is the part please? :)
Hello Andy,
I changed mine about 6 month ago, not difficult, take a little time though. The important part is to make sure the steering wheel is locked to keep it in the right place. It's easier when 2 person when putting bak the shatf but I manage myself easily enough.
The part is about a tenner and you'll find a difference in the air of the cabin as the fumes from the engine will be blocked from entering.
All the best.
Olivier
Just reading the useful sticky link, I did not put the car on a ramp, I did it all from above. Again, make sure the wheels are studdy and don't turn and take the key out to lock the sterringwheel in position.
Never thought of this am now going out for a look maybe where the funny smell is coming from in my car:D
Lynall
Andy, did you had a time fix it?
All my electronics now work on the car, beside the glows relay or a burst glow, but now as the pump is changed/ coded, it's all good.
