S320 Judder above 70 mph
The front tyres are cheap and nasty budget ones and are showing signs of weakness on the side walls
Good luck with this. Let us know what the cause of this is if you find out.
Maybe it's not relevant, but are the tyres inflated to the PSI/bar figures indicated on the fuel filler flap?
I bought the car with full service history, as advertised, but have since found out,through checking, that this was not the case.
Surely if it's not as advertised then you have a pretty strong case for a refund?
I don't think you should be in a position where the seller claims to be chasing the trader for compensation, which they will then pass on to you.
I know you bought it with no warranty, but I feel you're getting a tough break here.
Hope you get a decent resolution either way.
