WolfieS
Hi, I have asked before, however … I’ve fitted an Alpine Head Unit into my 2005 SL350 (R230) where the FM reception is nowhere as good as the original. I received some excellent advice from ‘Richard’ concerning the feed to the Audio Gateway (thanks again), but I want to check whether I have done as much as I can. Advice requested as follows:
• After connecting a switched +12v feed to the Blue wire(s) entering the Audio Gateway, I was able to receive an FM signal at the Alpine Head Unit. Does this feed at the Audio Gateway also power the FM amplifiers hidden somewhere deep within the dash?
• If I need to separately power the FM amplifiers, is there an easy way to do this without dismantling much of the dash? IE, do 'blue' wire(s) appear somewhere easy to reach that I should apply +12v to?
• Would I need to individually power each amplifier (presume that there are 2 – one each side below the windscreen somewhere)? If so, same question concerning access as above.
Thanks in advance and hope that somebody can clarify/confirm whether I have done as much as I can to restore an FM audio signal from the in-windscreen antenna(s).
Regards
Wolfie Souter
Westbury, Wilts, UK
Regards
Wolfie Souter
Westbury, Wilts, UK
