cardiffrob
- Dec 13, 2008
2002 SL500. It had a habit of getting the SRS light come on and stay. It gave a fault code of Passenger Seat pretensioner (or something similar) but no fault could be traced. Eventually, the drivers' side seat got lifted out and it became obvious that someone had butchered the yellow plug for the airbag wiring under the seat and had made a poor splice using a heat-crimp that hadn't been fully heated. Every time you went over a big enough bump it would shake the crimp enough to get a momentary dead connection. It took nearly 6 months and 4 visits to the stealers to get it solved, but I haven't had to pay a penny!
So, the tip is.....don't assume that the car knows which side the passenger sits on!
At last...a victory in the battle against Merc quality control.
