SilverBoar
- Nov 22, 2015
- SLK230 Kompressor
These are the symptoms: most dashboard warning lights showing; radiator cooling fan running from when ignition is turned on; jerks into and out of gear from neutral; battery ran down with ignition turned off.
Bristol, UK based: We have had very heavy rain, deep curbside puddles that have sloshed into the wheel arches with some pressure.
Everything else appears to operate correctly, and after a couple of hours of charging the battery the ignition fired up OK and some of the dash warning lights went out.
Any ideas?
Any ideas?
