Ooooh niceToday's figures mainly motorway
Bishop Stafford services £1,99.99 v power![]()
Does it often go into that coasting / gliding mode thing while in comfort mode ? If so, I reckon it can go that high in the right handsI'm still getting 38+ on my commute. Record 39.6 ....
Finally got out on some B roads on the way home .... why do people do 40 in a 60 and then 40 in a 30 ... grrrr![]()
I sit in comfort mode and switch out when I want a blast. 9th gear 70 mph = 1500 rpm ish.Does it often go into that coasting / gliding mode thing while in comfort mode ? If so, I reckon it can go that high in the right hands
It balances out my Maserati lolThat's not far off my pic apart from the MPG![]()
It's just the type of driving I'm doing, a long commute sat at 70 is relatively efficient obviously. I'm also driving quite often at weekends or in the early hours. I used to get only a little bit less out of my 5.0 RCF.That's impressive. Best long run I ever had was 30mpg on long day's drive, usually around 27 to 28.5 on similar long cruises even when trying to be good
Best:
More typical
Usual combined mpg
No trip was possible without a fair amount of sports plus. The figures you're achieving with your c63 are off the charts![]()
Even not trying to be economical, I'm getting over 34 on my commute.That's impressive. Best long run I ever had was 30mpg on long day's drive, usually around 27 to 28.5 on similar long cruises even when trying to be good
Best:
More typical
Usual combined mpg
