- May 5, 2004
- Location
- Surrey/Cotswolds
- W169 A, W205 C, R172 SLC, W447 vantastic
Is that coding (corner adaptive lights) only available on HID lights?
Nope. I have it on my A class which doesnt have Xenons
No had it done on my normal lights, but then I had it turned off again as I didn't like the broken foglight look!
What does the change actually do then? (confused by the "broken foglight look" comment)
I forget the exact spec's for speeds and angles but basically if you are moving below a certain speed and the steering wheel is turned more than a preset angle the car activates the fog lamp on the side of the car you are turning toward.What does the change actually do then? (confused by the "broken foglight look" comment)
Edit - Malc got a reply up first i see
If you look in my gallery and click on the appropriate thumbnail you'll see what I mean.
http://www.mbclub.co.uk/forums/showthread.php?t=9495
In all honesty I don't know. I will rely on the knowledge of the masses on that one. Can I open that question up to the forum? Car is a 2004 '04 plate (pre facelift) model.Were cornering lights an option on your model/year?
Took the car down to the local indie for some star mods-
1. Adaptive cornering
2. Gallons left
3. Park assist mirror
4. tyre pressure monitor
5. KPH replaced with temp
Ahh, so as I see it then I have 2 choices.....Yours is pre-facelift - so although there is menus about cornering lights, they may not work (my SL is same)
Gallons left almost certainly can be done
Park assist mirror requires memory mirrors (to be able to put them back to where they were), which in UK spec means memory seats
TPM (or more accurately) 'tyre pressure loss warner' is a facelift thing I think. TPM is the system with sensors, tplw uses the ABS sensors to detect a slowing wheel
UK mode can be switched off on pre-facelift
R
Is your car a pre facelift model? What have you had activated so far?I have all the features activated, but not the foglight when cornering as this i did not like!
some features work and some dont (autofolding), i have yet to fit my new front sam from a facelift model and i should be able to have full fuctionality!
What is involved in the new sam then? Is it an expensive and complicated job?my car is a pre-facelift, so far i have activated:
fuel tank content
remaining milage
kph to temp (can select what to display in main screen)
digital speed reading
auto folding (not functioning have to install new sam unit)
memory mirrors
auto dipping (both sides -installed german fully loaded dirvers mirror frame)
conering lights (not functioning have to install new sam unit)
key dependant settings
easy entry/exit
and may add trye pressure monitor depending on cost.
