The wood one looks like it was bought from www.gericia.com![]()
To be honest, im pretty sure it came from KMS in birmingham... it came with the car and looks almost new..
plumbers freeze? i can get this from a plumbing shop presumably?
cars in the garage at home, im going to bring it to work tomorrow as it was a bit of a trick trying to hold the steering wheel tight with my feet and trying to keep the ratchet centred... so another pair of hands and some more brutal tools may be needed...
right well some muppet, whoever fitted the wooden steering wheel pre my ownership, thought it would be a good idea to round of the hex nut that holds the wheel on..
so my attempts with the correct hex socket and ratchet last night just made matters worse as it is very very tight..
im going to have to try a long tyre lever bar on my socket and if that doesnt work i guess im going to have to find a long metal drill to destroy the head of the bolt???
Malclom - any clever ideas here, its so far recessed its difficult to work the bolt..
have ordered a new bolt anyway..
You'll need a big breaker bar and a very good socket, I think it's something like 10 or 12mm from memory.
Even when they're on normally they're extremely tight, you'll need an assistant to hold the wheel very strongly. Then make sure you keep the socket very straight and get some decent leverage on the bar.
The bolt is thread locked and possibly tapered from what I remember, about £2 or £3 for a new one.
I've got a strong 2ft snap-on bar and socket which was very useful for this on one of my 190s.
Will
I would suggest using a slightly smaller socket, tap it on over the bolt. Get some one to steady the wheel and using a long lever on the socket ease the bolt loose.
With 80Nm, that's going to take some shifting. I would be worried about damaging the steering column striking it hard enough to shift that. Never mind the possiblity of slipping off the bolt and damaging the steering wheel!
