mrcbenz
Hi everyone,
I noticed that the front off-side tyre was quite low compared to the other three. The tyre was almost touching the wheel arch. My airmatic setting was on the raised position. When I put the key in the ignition, the above message appeared. I drove the car a few paces forward, stopped to check the front off-side tyre and it seemed to raise a little and managed to drive home. When the engine was stopped, no malfunction messages appeared. I had a new airmatic pump just under a year ago. I suspect it's the strut as the other three tyres seem at the correct level.
Has anyone else experienced this and how much did it cost to remedy? It's booked in at my local indie to check at the end of the week. Car is a 52 plate with 112K on the clock. Not sure if the shocks were replaced from new as I've only had the car for 19 months or so.
Many thanks.
Many thanks.
