Tarnished aluminium trim
Charles Morgan
Mercedes 250CE W114, Alfa Romeo GT Coupe 3.2 V6
My red car has a lot of aluminium trim that was pretty badly tarnished. Using Autosol got rid of much of the tarnish but still pretty flat to look at:
By chance I was using Meguiars Ultimate protectant on some of the black finish by the aluminium, and some of it ended up there - I wiped it off to notice there was much more of a sparkle and a richer finish. (photos taken with lousy iPhone but entirely unmanipulated). Not sure how long it will last, but definitely much better than untreated! Other tips for aluminium polishing welcome!
Do I get a prize for guessing the car ;) :cool:
Guess away.
The prize would be a mug of tea and a drive!
Looks the same to me. It's your imagination?
Was the aluminium bare? Normally when used as trim on cars, it normally has a clear coat, even on many classic cars. So normal process is to treat it like the rest of the paint on the car and use a paint compound polish, followed by refining polish.
If it's bare, you'll need to wet sand with a fine grit and then use a metal refining polish. Be aware that the finish won't last for long. However you could use one of modern sealants like Gtechniq C1/C4 to seal it in for ~2 years. You can then use a sealant like C2 or a wax to give it a bit more gloss.
cheers, Steve
Steve - I'd say whatever clear coat there was originally has gone (it's 30 years old - I suspect someone has used chrome polish with ill effect). So sanding, metal refining polish sounds like the way to go!
Charles, I presume this trim was silver originally?
The SL's trim pieces could do with improvement but unfortunately they're gunmetal so I suspect replacement is the only option.
I have used Metal Polishing Supplies with success in the past.
Their site shows their own YouTube video tutorials and they have a wide range of pastes, mops and sealants. LINK.
Around 10 miles from PCS.
