br1anstorm
Yes.... every actual or prospective SEC owner knows about this one. Sooner or later rust inevitably gets a hold along a panel seam below the rear window seal. Eventual result - damp patches in the boot, crumbly metal below the window, and large bills for removing/replacing glass and doing some cutting and welding.
I've just detected the first tiny signs in my otherwise rust-free car: a hint of rust showing if I peer up under the parcel shelf from inside the boot (torch, and gymnastic contortions, optional..)
Seems a bit drastic to ask a window shop or dealer to take out the rear window at this early stage to take a closer look. So here's the question: how (and how easily) can one remove the rear parcel shelf and/or rear seatbacks in order to get a better look at the rust-prone panel? I reckon that if one can get decent access, from both sides, to the vulnerable area, then some hard work sanding and cleaning, then rust inhibitor/converter (Kurust/Jenolite/Hammerite etc) and maybe some Waxoyl or Seek n' Seal might prevent a minor problem becoming a major one.
Advice on exactly how to take the seatbacks and parcel shelf out without breaking or losing clips, plastic bits and other fixings would be appreciated.
br1anstorm
br1anstorm
