- BBS LM’s (even though wider have saved 6.6kg plus whatever rotational mass)
- Conti sport 7 255/35 front 275/30 rear
- KW Clubsport coilovers with adjustable spherical bearing top mounts, custom kw springs with additional helper springs
- Ultra Racing front/rear strut braces with 6 under chassis bars
- Custom adjustable droplinks with spherical bearings
- Renntech Adjustable rear toe arms with spherical bearings
- KMAC rear adjustable camber arms with polly bushes
- Spoon ridgid subframe collars front/rear
- Full custom carbon fibre interior trim including dash, doors, centre console, armrest, rear vent & boot arm covers
- Full suspension geo and corner weight
- AMG expensive fuel cap
- AMG expensive door pins
- 507 edition grill & drl covers
- Mercedes gloss black door mirrors and boot spoiler
- Secondary cat delete
- Quaife LSD (may swap this for OS Giken)
Sat here waiting to be fitted when I get time
- 507/Black series bonnet
- Weistec larger transmission pan with custom Setrab additional oil cooler/fan
- Brembo 2 piece 380mm front discs with brake caliper bracket (though larger saves 6.6kg plus what ever rotational mass)
- Brembo 2 piece 360mm rear discs with C63 black series rear caliper
- Goodrich braided brake lines
- Custom Setrab large main oil cooler (this is 30% larger than both larger oil coolers fitted to the C63 Black Series
- Full W204 roof panel with sunroof delete (was never an option on the C63 so doing this will save 30kg + from the highest point on the car)
- Carbon Recaro pole positions (same as C63 black series option, these weigh 4.5kg each saving 40kg minimum over stock!)
- Custom T45 half rollcage which weighs 18kg, top and bottom rear seat weigh 25kg so 7kg saving with them removed with a seat panel delete.
- Synco design front upper & lower arms with spherical bearings
- Creative steel poly engine & gearbox mount
- Creative steel solid rear subframe bushes
Need to buy
- MBH headers/manifolds
- Mercedes SLS larger side oil cooler
- C63 black series track pack differential cooler
I think thats everything
hopefully save around 110-140kg when it’s finished which will add to the handling and feel like the rest of the parts have already done. Already saved 22kg from various parts.
