grober
MB Master
Aftermarket Engine preheater? OR a piece of cardboard or strong baking foil over the lower half of the radiator should help warm up time but keep a watchfull eye on the temp gauge.
What is the best way to warm an engine.
Takes ages being a derv to warm up
That's interesting. I had been wondering if diesels take longer to warm up because I know diesel burns cooler than petrol.
Does this also mean that cabin heaters in diesel cars are less good than in petrol cars?
Does the water in diesel cars run cooler, or are the cooling systems tuned so that the water is about the same temp as in a petrol?
They take longer simply because diesel engines are more efficient than petrol so there's less waste heat produced.That's interesting. I had been wondering if diesels take longer to warm up because I know diesel burns cooler than petrol.
:d:d:dwhats that para ? Chinese marmite ?
When I was a teenager, a little old lady near us used the following technique in winter when her Mini Clubman didn't start too well:
1. Mini won't start;
2. Return to house;
3. Return to car and put hot water bottle on engine.
4. Leave for 10 mins.
Can anyone guess No 5?![]()
Interesting, not noticed one in any Merc I've been in. The SL has a an oil pressure gauge which is pretty pointless IMHO as you only care if the pressure is low (and there's a warning light for that). Oil temp you'd use every time you drove the car.
Diesel engines also usually have more mass as they tend to be of a heavier construction than petrol engines.They take longer simply because diesel engines are more efficient than petrol so there's less waste heat produced.
