Andy
if you add refrigerant to a system to do a leak test are you not breaking the law?
i found that if you have a leak thats hard to find adding helium gas to the nitrogen for the pressure test some times helps to find the leak
helium as a smaller molecular structure then nitrogen therefore leaks at a faster rate and escapes from smaller holes
chilled
chilled
