st4
Banned
Turns out a clip has broken at the bottom if the inlet port motor. They've tested it and it works fine. Car getting fixed and I'll be back in shed on Thursday. Damned Christmas getting in the way of me and my shed
Hi, could be facing the same issue... what are the symptoms? Is it loss of power on the entire rev range?
It would be. very common problem on the V6. It's normally the motor, rather than the clip though.
Part not expensive, but a pig to get at so labour is more.
It probably is an EGR valve issue again, they are junk. Does it run OK for a few minutes then start playing up, or bad from the word go?
Limp home can be caused by any failing, you really do need the codes read. Yes, the V6 does have an EGR valve.
Dieselman said:It probably is an EGR valve issue again, they are junk. Does it run OK for a few minutes then start playing up, or bad from the word go?
I just recently had a little bit of servicing carried out and requested that the turbo seal was changed as a precautionary measure, 05 car 37k miles, independent said that their was
just a very very slight amount of oil, so fingers crossed.
I loved the smoothness and power of the V6 Diesel i had (2007 E320 Cdi), but the more I hear about the crap design which is otherwise known as the "inlet Port shut off motor" then the more pleased I am that I no longer own it...
Its a damned shame really but I think its a design fault thats inherrant with this particular V6 Diesel.
Is this a big job ? We've got an oil leak on ours.
Other than the occasional injector fault 270CDi rarely seem to suffer with anything due to using vacuum EGR valve and no inlet port flaps.
The older sludge burners really are the best though...
davidjpowell said:I remember thinking that a few times about the money-pit. Sady there were always more woes to come!
