got an annoying intermittent problem with the car cutting out, seems pretty certain it's the pump relay that's causing it. I made a classic get-you-home bodge today by connecting the pump wiring in the boot to a feed from the rear fog light circuit, but that's hardly a long-term solution. Having done that and set off up the road, within a couple of minutes the car ran as normal without feeding power to the pump, so obviously the relay decided to play ball again.
Now, the relay appears to be a clever one that senses engine speed and also has a rev limiter function... and it's quite possible that there's a dry joint in it or something. I could easily investigate that if I could find the bloody thing. It's a 1981 car, RHD, if that makes any difference.
