W123 drive shafts
Llewelyn
S210 320CDi D6
Can the rubber boots be replaced, and if so what kind of job is it?
I notice that the ones on mine look pretty old and cracked, and when jacked up at full suspension travel, a bit of oil leaked from one of the outer ones. Oil? ah well. could be right, I've not checked - I normally expect grease in driveshaft joins like that.
failing that, anyone got any decent shafts going cheap, for an '81 280CE in case it makes any difference, which I don't think it does.
it'd be kind of helpful if i could use the PM system, what the heck is the idea of *30* posts til you can use it ??
ah well, google search and email will no doubt serve...
