bolide
I want a future proof set up in that I'd like a system that could handle more power if I ever decided to go down that route
I think the setup should be dictated by your useage, not by the power output. If you're doing track work you'll want it stiffer and with less roll. If you're doing Autobahn work I would think standard would be best. For most UK roads I'd think standard with SLS rear would be hard to beat
which is why I think the OEM system is not the best option.
I don't think that follows. I think the assumption that lower + harder = better is probably untrue for most UK road situations. Without seeing how good a standard system can be I don't think you can assume a different setup will be better
Nick Froome
