Im sure stock shocks are ok... you have to remove one section of the bump stop though...
yes it doesdont ask me for a part number though as i didnt write it down when I had the exhaust redone.... pretty sure its a W210 part number..
Yeah thats what I think to, but if you see a pic of the car, its more dragster like set up and I do not think has been lowered that much at the rear.
I imagine the spring rate will be shown in N/mm. To convert that to lb / in multiply by 5.7
I'd be interested to know what the spring rate is, front & rear
Nick Froome
www.w124.co.uk
Mit Niveau-regulierung is with self-levelling suspension and ohne is without. Schraubenfeder will be spring, Aubendurchmesser will be outside diameter, Drahtdurchmesser is wire diameter and I think Gesamtwindungszahl will the number of turns ("totally turns counted")
So the front springs are 110 mm diameter (4.4"), wire diameter is 16 mm (about 0.6"), free length is 365 mm (14.4") and there are 10.25 turns
Rears are 4" diameter, 14 mm wire, free length is 290 mm (11.4") and there are 9.8 turns
No word on spring rate
Nick Froome
www.w124.co.uk
I would think the adjustable top mounts would be overkill for a road car and they'd allow a lot more NVH into the cabin. They useful for adjusting camber on race cars which run lots of negative camber with sticky tyres but unless you're cornering on the doorhandles with sticky tyres I don't think you'll find a benefit
Nick Froome
www.w124.co.uk
This was my reasoning behind not getting a set.
On 500E.com they rave about them, ye when my top mounts had gone hard and were 16 years old the difference between them and new ones was quite obvious. Less NVH in the cabin and expecially on badly cared for roads.
Are your front tyres wearing evenly?
Dave!
Wearing on inners and as per all previous posts etc, gonna get Brabus springs fitted, new dampers, new mounts, new bumps stops with 1 segment removed and new spring pads, see how we go with that
Paddy
Ahh, sorry I had it in my head that only the rears were wearing unevenly.
Dave
