w124 Diff mount removal - Stuck half way
aka$h
London
Anything with a 3 Pointed Star!
Ive needed to change the diff mounts for quite sometime and decided to tackle it yesterday. I disconnected the prop and drive shafts then disconnected the abs sensor, and removed the 3 bolts holding the diff in place.
Now Ive got a problem, I can get the mounts out of the sub-frame.
Ive had a quick search and it would seem I need one of these:
http://www.performanceproducts4benz.com/productpage.aspx?pid=105960&name=Sub+Frame+Bushing+Tool
Does anyone know of a similar tool that is likely to be available off the shelf here?
Couldn't you just use some threaded bar and some nuts and washers?
In addition a piece of tube used with the threaded bar works a treat.
